turn thread with L97
Results 1 to 5 of 5
Thread: turn thread with L97
    werkzeugmacher81's Avatar
    Oct 2008
    Offenburg
    Hello dear community!
    We have a problem with the thread turning L97. I hope that somebody can help me out..
    It’s about an internal thread- the machine positions the tool too suddenly- I don’t think it will lasts long this way as we have to produce about 2000 parts a month- so we are looking for a “machine friendly solution”. We have a Siemens 840C controller.
    Is there a possibility to reduce the rapid traverse before the cycle?
    Our cycle looks like this: R20=2 R21=36 R22=-30 R23=0 R24=1.2 R25=0.05 R26=1 R27=3 R28=7 R29=0 R31=36 R32=5 L97 P1
    Thank you!
    TX8-D's Avatar
    Nov 2004
    Großniedesheim
    Morning
    The only possibility that I see is that you maybe position with g01 before the thread cycle.
    So G01 x 40 z5 F2 or so...
    Does it jerk before the thread cycle or in rapid traverse in general?
    Regards
    Rücky
    <span style='font-family:Arial'><span style='font-size:14pt;line-height:100%'><span style='color:red'>&quot;Wenn Windows die Lösung ist. <br>Kann ich dann das Problem wieder haben?&quot; </span></span></span><br><br>
    Oct 2008
    Offenburg
    Hello
    It jerks in the middle of the cycle, when it runs free and pre-positions again.
    I have played around with different turning speeds, without success. Even with 800U/min I have the same problem. The material is aluminium- it worked perfectly with external threads also with 1500U/min
    Regards
    TX8-D's Avatar
    Nov 2004
    Großniedesheim
    Morning
    Are you processing with or without thread undercut?
    But first of all a general question: what machine are we talking about?
    As far as I know, with Montforts you have an M command that defines how the machine drives out of the gear
    Oct 2008
    Offenburg
    It's a Gildemeister Sprint, year 1997
