Does anybody know if the controller is suitable for this kind of processing? It’s possible to process almost everything but I have to say that the Mazak controller is very nice and easy to use.
How can you process a part from 3 side with that controller? IS the NP dragged along (MillPlus) or do I create an UP for each side and then call it in the main program to process it (Mazak)
Hello Steff
The 840 C was a good controller during its high season but since the end of the 90s, only the 840D is sold. That means that there were no further developments!
What the machine can do or can’t do depends on its features. With Siemens- you are/were able to order almost everything – but normally only as an option.
And then it also depends on how many ‘hits’ the machine got in it’s ‘life’.
