spindle doesn't start
Results 1 to 3 of 3
Thread: spindle doesn't start
    drehteufel's Avatar
    Apr 2009
    Hello CNC community
    I have problems to start
    the main spindle in the manual drive.
    I have a Siemens 880T. The keyboard is identical to the 820T. I think the handling too. ..
    The machine is a Weiler DZ 42 with 2 carriages and opposed spindle.
    Unfortunately, I never came in contact with such controller , I’m not sure if I my approach is correct. The manual doesn’t help much either- I only managed the reference run with the help of the manual.
    To find out if I make any errors or if the machine is broken, maybe somebody could check my course of action:
    set-up operation > JOG> overwrite - here I enter the files like the mask provides it.
    e.g.: S1=2000 M1= 3 T1=1 D= 1
    On the screen the following message:
    Enter file > NC-Start
    Kind regards
    InTex's Avatar
    Feb 2007
    Schladen / Harz
    Enter M40 before and press cycle start
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
    drehteufel's Avatar
    Apr 2009
    Hello Intex
    Thank you for the advice.
    I finally found the error with the help of Weiler’s customer service.
    The key switch was set to ‘set-up operation ’
    However, I guess I will have many more questions in the future though.
    Kind regards
spindle doesn&#39;t start
