override write protection to change zero offset
Results 1 to 2 of 2
Thread: override write protection to change zero offset
    Registered Hanemann's Avatar
    Jun 2011
    Karlsruhe
    I have the controller 802d sl pro for milling.
    I want to undertake a zero offset in order to set the work piece neutral point again.
    However I always get the message that there is a write protection in place,when I enter the measured values.
    How can I eliminate the write- protection or can I bypass this problem?
    I have bought the machine in a used condition, that’s why I have the problem now.
    Many thanks for any information.
    Boern's Avatar
    Nov 2004
    im Raum Metzingen
    Hello
    Have you got a key switch on your controller?
    Maybe this will help you out:
    http://support.automation.siemens.com/WW/l...bjaction=csopen
    Regards
    Boern
    <b><br />Das dringendste Problem der Technologie von heute ist nicht mehr die Befriedigung von Grundbedürfnissen und uralten Wünschen der Menschen, sondern die Beseitigung von Übeln und Schäden, welche uns die Technologie von gestern hinterlassen hat.</b><br /><br />Dennis Gabor (1900-79), ungar.-brit. Physiker, Entwickler der Holographie, 1971 Nobelpr.
