Can some one help me with the following NC program?
I first drew it in Millwrite 2000 sent to floppy then opened in Mach2 I am able to engrave it but it is inverted starts on the left –Y cuts the text to the right + Y with the top of text facing the + x direction. It used to start on the y + side and cut towards the –Y side with the top of text towards the – x direction? The second thing it is doing is I set the text height to .500” tall it engraves at .130” tall. So I made a new file set the text height to .750” and then it cut only about .200” tall? It is probably something very easy.
Thanks Clint
O1111;PUT YOUR PROGRAM NUMBER HERE
G80G40G17
M06T1
G90
M03S5000F15.0
M08
G00X0.3971Y0.5026
G00Z0.05
G01Z-0.0087F6.
G03X0.3266Y0.5668I-0.1393J-0.0821F15.
G03X0.1452Y0.5556I-0.0805J-0.171
G03X0.0411Y0.4315I0.1422J-0.225
G03X0.0542Y0.1423I0.3184J-0.1305
G03X0.1602Y0.0369I0.2181J0.1134
G03X0.3173Y0.0245I0.0935J0.1825
G03X0.4127Y0.1124I-0.0483J0.1481
G00Z0.05
G00X0.6408Y0.0175
G01Z-0.0087F6.
G01Y0.5825F15.
G00Z0.05
G00Y0.0175
G00X0.887
G01Z-0.0087F6.
G01Y0.403F15.
G00Z0.05
G00X0.8701Y0.5656
G01Z-0.0087F6.
G03X0.8701Y0.5995I0.J0.017F15.
G03X0.8701Y0.5656I0.J-0.017
G00Z0.05
G00X1.1072Y0.0175
G01Z-0.0087F6.
G01Y0.4097F15.
G00Z0.05
G00Y0.3459
G01Z-0.0087F6.
G02X1.2029Y0.3985I0.1109J-0.0882F15.
G02X1.3984Y0.223I0.0189J-0.1756
G01Y0.0175
G00Z0.05
G00X1.5693Y0.413
G01Z-0.0087F6.
G01X1.7086F15.
G00Z0.05
G00X1.6295Y0.5825
G01Z-0.0087F6.
G01Y0.1005F15.
G03X1.7094Y0.0175I0.0831J0.
G00Z0.05
M30
I figured it out I had my steps per unit set to 2000 in Mach2 then I wound up setting it to 8000 to get it to engrave the same size as what was drawn. Now I need to figure out why it engraves its way to the begining of the text. then it raises up from cutting each letter.
Thanks Clint
