http://www.8linx.com/cnc/cnc.htm
http://www.teaser.fr/~abrea/cncnet/table/tables.phtml
Second one is in French, but good stuff.
Hi all
I would like to know if there are any tutorials out there on foam cutting,as i would like to build a foam cutter foe my wings.I have the the electroncs and motors which i think will do the job,but its how do make the files for the cutting ,are they in G code /dat files /dxf format. i use Profili at the moment for makeing my Ribs ect, so can any one point me in the right direction
Thanks Bill
- New Machine Build- Our very first CNC foam cutting
- Cutting XPS foam
- Foam cutting CNC
- Foam cutting CNC
Hi Many thanks for the links, i have to start learning French,they seem to have a lot on the forums, i was hopeing there would be some on this forum,
Regards Bill
Try this web sight
They have software for cutting wings. Starts at about $38
Compufoil.com
onthemarc
Hello all,
I'm planning to make the CNC foam cutter from 8linx and the controller from HobbyCNC. The problem is with the software. I currently have IntelliCAD 2000 which will do DXF files but what inexpensive software can anyone recommend to translate the DXF file to the driver and what software does one use to make different cuts at each end. My example would be two airfiols with different chords at the ends of each wire? Does that make sense? Thanks.
Butch
Butch
