Hi All, I have KL-11078 stepping driver to control hybrid stepping motor at 8 wires.( 1200 Oz-in). I would like to know the power supply for this driver. I know it use at 110 VAC but I don't know what amps is compatible with this.Pls advise. MongkolSimilar Threads: Stepping mode of unipolar driver Stepping Motor Driver IC THB6064H THB6064H stepping Motor Driver IC4.5ANeed Help!- Stepping Motor Driver 80V 6A Micro stepping Motor driver
if you wire the motor as Bipolar Paralle, the rated Current is 6A, So you can set at 6A in your driver by DIP switch
Forum Rules
