Trying to reload the system tapes on the above machines due to memory loss after a long storage period.
Problems encountered are thus:
1. Sometimes the tapereader reads the tapes but stops after a few seconds sometimes longer. I have even managed to read a complete tape, but of course the same problem came up when loading reel two. I suspect a tapereader error!?
2. Got the tapes on disk in ASCII format trying to load them this way. Can`t get the PC to communicate with the CNC. I will check out the RS232 with a break out box tester. Never used one before, what do I look for? Got various suggestions for DNC setup, does anybody know something that works, including cabling?
3. When starting up the machine I get a one-line message "memory lost.... ". Doing the firmware diagnostics and tapeloading (as described above) works when this message is on, but sometimes the screen is full of letters in a caotic and random and nothing works. Any suggestions what this may be and how the get the machine "back to normal"?
Comment to all above: Quite sure that the boards and other hardware are OK, the diagnostics reports no error. Got two machines so I can interchange parts if I suspect any faulty parts.
I feel your pain...
I don't have to run this machine as I am the programmer.
My only advice for you, If you are determined to keep the machine, replace the control with a retrofit (replacement) control.
We have one Cinc 10vc2000 left, and I can't wait untill it goes the way of the dinosaur...
I see you're in Norway, as in the Netherlands?
Good luck to you,
Thanks for your reply, Scott_bob.
Haven`t got the money to replace them, anyway I have never used them. Retrofit is expensive too.
Yes, Norway, Scandinavia.
