- Need measure
Member
most workbench are 32" hight (812.8 mm) you can make it as long and wide as you want and Welcome to the zone
Ciao Tito,
Devi scusare il mi italiano...
Quale distanza vuoi?
Dal base tra il tavolo, o
la distanza da la sinistra parte dal tavolo quando il tavolo e' al sinistra tra la destra parte dal tavolo quando la tavolo e' al destra - Larghezza massimo? Il secondo depende dal larghezza del tavolo.
Or in English...
Are you looking for the height from the base to the table or the maximum width including table motion. The second one depends on the with of the table. The machine available in Italy may have a different size table than the IH model.
ciao
lino
Member
thank you for reply,
llino you wrote in very good italian, i'm looking for the maximum width including table motion
you are right, at the moment the table of mill on sale in Italy is 31.5" wide instead of 39.5" IH mill, but there are the possibility to import a version with the same size
Tito
Tito,
On my IH mill, I measure 86.5" from tip of hand wheel to tip of hand wheel including full table travel.
ciao
lino
mmm..., 86.5" are too much for my garage
i really need 20" of travel not 30" as IH mill
ok, thank you for fast reply, probably i'll buy the ZAY7045 with the table wide enough for my needs
but...
within december i must complete my router, 'cause near my house the money don't grow on the tree
Tito
- Need measure
- You may not post replies
- You may not edit your posts
Forum Rules
