Hello CNC Friends,
the following machines are now offered on our online marketplace for used machines:
1 Centre lathes
1 Vertical borer, double column
5 Toolroom / tool die milling machines
1 Bed milling machines (moving column)
1 Other and special purpose milling machines
3 Bench and Column type drilling machines
1 Radial drilling machines
1 Rapid radial drilling machines
2 Machining Centers (Vertical)
1 Machining Centers (Horizontal)
1 Slotting machines
1 Centerless Grinders
3 Tool grinding machines
5 Double grinding wheel machine
2 H-frame eccentric presses
2 High speed Punching machines
1 Manual Folding machines
1 Hydraulic operated Bending Rolls
1 Coiler straightening machines
3 Laser Cutting Machines
1 Rotary Shears
1 Bend-, straight- and reducing for pipes bars profiles
1 Induction profile and tube bending machines
97 Accessories - Welding
16 W E L D I N G
1 Associated Mass Finishing Equipment
1 Pressbrakes
Kind regards,
USED MACHINES TEAM
