Remachining makes your life easier if you work with complex objects. The concept is to find areas such as corners and radius where the previous (bigger) cutter didn't make it all the way in and then (re)machine those areas only.
You can more or less do the same thing by using regions and force the second cutter to run where there should be material left. It's not automatic and you probably cut some air too, but it works if you're satisfied with a bit longer less effective programs and a longer working process in Rhino.
Is money an issue? Go 4X license
Is money not an issue? Well...
Hope that helps.
