Hi Jazz411 ,
does this diagram help ?
John
Hi I wiring up some G203v's I am using the diagram from homann designs I have edited out what is irelevant at this time. I need help wiring the power plug rocker switch and grounding it all to the chassis. How do what check what wire is what phase.
Thanks.
Hi Jazz411 ,
John
Hi Jazz411 ,
the Earth bond to the machine is the earth connection to
the metal enclosure for your electronics ( G203v 's etc)
and the body of your CNC machine assuming thats also made of metal
John
Just one cable. The colour convention is yellow and green striped. If you only have single colour, I'd go with green.
What I have two ?
Sorry I misread I thought you said stripped.
Hi Jazz411 ,
the wiring colours I've used are the new colours used in the UK since we harmonised with europe
adding the yellow stripe ensures people that are Red/Green colour blind can correctly
identify the Earth wire
(the down side being black was neutral and is now one of three phases (live)
blue was another phase and is now neutral you can see the danger with a mix of old and new wiring !!!)
as in Autrailia , the old colours used for single phase supplies are:-
red is live , black is neutral and green is earth
the difference being the UK plug is fitted with a 1A to 13A fuse
for you I've found this :--
240V powerplug datasheet
John
Thanks again.
