Since you were provided with the models for this machine, the .stl files are embedded in the .esm and are loaded in a temp folder. You can contact who ever gave you the .esm and see if they can give you the .stl for the base, or you can create one yourself and in your machine setup page under the assembly tab, you can point the machine base solid to a new .stl
BG
