Originally Posted by
LeeWay
On all three of my machines, I have had to add additional switches to prevent just this sort of thing.
On my lathe, when I start Mach, hit reset, the spindle starts then by itself.
I have to physically start and stop the spindle on screen before I actually turn on the spindle switch before it operates correctly. It is using a DC motor.
My mill works as it should. If I turn it off though and get ready to shut down the computer as well, it will start up before the computer is completely shut down. I first turn ff power to spindle before shut down. Also a DC motor.
My router runs off a large relay. It will act just like the mill. If I shut the computer down with the PS to motors and BOB still powered, it will also start the spindle.
Just odd quirks I have learned to work around so far.
I intend to get the Charge Pump boards though and install those.
Also working on my second mill box now and want to do it right as well, so it will have a charge pump circuit from the start.
