Run service code 97 , that should prompt
you to move axis + - then be right. inc set
Mark
Need help
I have milling machine with ProtoTrak M2 controller, this is used equipment and I am new to CNC programming. Everything work fine except polarity of x, y, z axis are displayed in reverse (measurement to the right in x direction should be positive but in my situation shoving negative sign) Running code 99 to preset to factory defaults did not changed axis polarity. It is very annoying to see mirror image in graphics display.
Mark
"I'll keep my gun, my ammo, my money, my freedom and you can keep the [COLOR="Red"]"CHANGE"[/COLOR] !
