Hi Alex,
Let’s start with an external push button for FeedHold.
The switch must be wired to a KFLOP or Kanalog input have you done this? Any available input can be used because we will be writing a program to watch it.
One way is to use IO16-23 on JP4 or IO26-33 on JP6 which have pull down resistors and just switch the pin to 3.3V
Does it change on the Digital IO Screen?
Next run the Example ExternalFeedhold.c (attached) in an unused thread like Thread #7 in the C Program Screen.
Change the number 46 to the bit you wired the switch to
Let us know how far you get.
Regards
