First I would swap the signal wires from wincnc and make sure the step and direction signals are doing what you expect. If that's the issue you can rewire it and use different ports. Talk to Ben if you call them again. Another thing to consider is the drive requires programming. It can be done manually, if you look up the manual on it. If all that fails, I would swap the motor output wires on two drives and verify the motor,wiring, ect are all good. It's possible you have two bad drives, but swapping things around for testing will tell you. If your close to Houston and want help send me a pm.
