Air op conversion
Results 1 to 2 of 2
Thread: Air op conversion
    May 2016
    Default Air op conversion
    I finally got off my butt and completed my air op conversion on my machine. Mounted a shortened 2 stage air cylinder without drilling a single hole in the machine. Manufactured supports with 2 diagonal having support blocks above and below z axis. Brackets below z axis prevent any possibility of support spread. All steel parts TIG welded. Control valve is mounted to small steel plate bolted to trailer light magnet. It's massive overkill on support but leaves easy accessibility to everything.
    Attached Thumbnails Attached Thumbnails Air op conversion-control-valve-jpg   Air op conversion-spindle-bracket-jpg   Air op conversion-control-valve-jpg   Air op conversion-spindle-bracket-jpg
    Nov 2011
    Default Re: Air op conversion
    I see the new machines have the power drawbar as a standard feature plus a BT 30 spindle- nice upgrades .
Air op conversion
Air op conversion
