- Preload on spindle shafts
I am in the process of upgrading my MIll Turn control system. In the process, I am adding encoders to both spindles. I need to remove the nut on the lathe that holds a spacer sleeve. I am going to shorten the sleeve and add a timing pulley to drive the encoder. I am going to do a similar thing to the mill spindle.
Does anyone know how to set the preload on these shafts?
Thanks,
- You may not post replies
- You may not edit your posts
Forum Rules
