collete upgrade to shoptask 1720
Results 1 to 2 of 2
Thread: collete upgrade to shoptask 1720
    Apr 2015
    Default collete upgrade to shoptask 1720
    i hope this post helps someone.
    i got tired of swapping out the mt3 tools on my 1720.
    i decided to try and upgrade to a collet system.
    none of the vendor out there seem to sell a kit.
    i ended up winging it
    as i so often do.
    so i bought an er32 mt3 m12 cheap collet set off of amazon.
    i then bought some m12 thread rod and an m12 nut for the drawbar.
    i welded the nut to the bar..the nut is an 18mm serrated flange nut.
    here are some pics
    runout was .0012
    no sure if thats good or not..im a novice..
    Attached Thumbnails Attached Thumbnails collete upgrade to shoptask 1720-20200502_115409-jpg   collete upgrade to shoptask 1720-20200502_114100-jpg
    Default Re: collete upgrade to shoptask 1720
    I picked up a similar set, but it's not answering the problem of short quill travel and working between short mills and longer drills and wigglers etc. Hard to work through a job without re-clamping the work at different heights.
    Sent from my SM-G950U using Tapatalk
