cnc rotary table
Results 1 to 2 of 2
Thread: cnc rotary table
    Member prainma2006's Avatar
    Apr 2019
    Default cnc rotary table
    I just got my new toy used(2015 Mill/Turn) and the guy gave me what he had in regards to Mach 3 Mill, Mach 3 turn, and very light on the Shopmaster literature, said there was a lot of research that could be done online, cant find a whole lot. Anyways, have it running, learning what I can, noticed there is an open axis plug in on the Gecko 540, did a little research, looks like eiter a CNC tool post or rotary table, for what Im thinking for me would best be used with a rotary table, got on Shopmasters website, and they dont sell them anymore, but give them with the system. Found a no name one on Ebay, that can be sent with the 540 recepticle, that should be all I need right, then obviously going in and activating some items in Mach 3. Those of you guys that have the cnc rotary, is it something you use very much? thanks in advance, Mark
    Apr 2004
    Oakland CA USA
    Default Re: cnc rotary table
    Yes, you can run another stepper off the 4th port in the G-540. And a rotary table can be quite handy for some projects. Without knowing what you intend to do, it's hard to say whether that thing you found will be sufficient for your needs. But some of those "no name" 4th axis kits on Ebay don't have much (or any) gear reduction, have lots of slop in the bearings, and don't support the 4-jaw chuck you'd need to hold anything but round stock. Buyer beware,,,.
    Andrew Werby
    https://computersculpture.com/
cnc rotary table
cnc rotary table
cnc rotary table
