- Accuracy tuning
Accuracy tuning
Hello guys so I have my mill turn running. Doing lathe portion right now. I figured out took touch off and home. I’m using msm adding for Mach 3. Part I ran had a major od of .340 and minimum of 325. One part came out at .325 major and 275 minor. I moved the wear offset for x +.015. Im not sure where to go from here my dro abd Mach 3 numbers do not match so I’m assuming that might be it, anyone dealt with this already? I will move into mill once my lathe is figured out. Z depth was good on it.
- Accuracy tuning
- You may not post replies
- You may not edit your posts
Forum Rules
