Touch off
Results 1 to 3 of 3
Thread: Touch off
    Jan 2018
    Default Touch off
    Hello, I have a shopmaster mill turn. I am having issues with Mach3 turn, the machine does not have home switches and I'm having a hard time touching off tools. Everytime I touch off x axis and input dimensions of the cut when I set to G0X0 with the tool called it is always off. Almost as if the settings are incorrect or something... The stepper motors c are not skipping. Any help or suggestions
    Member Goodlett's Avatar
    Aug 2011
    Default Re: Touch off
    How do the numbers on the Delos dro compare to the Mach 3 dro? Is there some lost movement somewhere? Are the steps per unit set up correctly? Backlash?
    Maybe a video would help.
    Aug 2011
    This is my ports and pins set up in lathe mode. Hopefully it helps.
    Attached Thumbnails Attached Thumbnails Touch off-img_3235-jpg   Touch off-img_3236-jpg   Touch off-img_3237-jpg   Touch off-img_3238-jpg
    Touch off-img_3239-jpg   Touch off-img_3240-jpg   Touch off-img_3241-jpg
Touch off
Touch off
