Need Help! Corrupt File, SRAMxxx.FDB - Sharp SV2412 w/ FANUC Oi-MC
Results 1 to 4 of 4
Thread: Corrupt File, SRAMxxx.FDB - Sharp SV2412 w/ FANUC Oi-MC
    Feb 2013
    Default Corrupt File, SRAMxxx.FDB - Sharp SV2412 w/ FANUC Oi-MC
    Hi All,
    So far, neither FANUC nor Sharp has been able to source the files I need. The control on my 2007 SV2412S corrupted the SRAM1_0A.FDB and SRAM1_0B.FDB files and the machine boots to alarm 935 / SRAM ECC error. Does anyone have a similar machine that can dump these two files and email to me? I'd really appreciate the help.
    Ken
    (kenneth.s.shinn@gmail)
    Apr 2011
    Default Re: Corrupt File, SRAMxxx.FDB - Sharp SV2412 w/ FANUC Oi-MC
    Your memory is corrupt and may be fixed if all memory has not been cleared. I had a similar problem on a 31iA control and I backed up the SRAM just in case it wasn’t related to corrupted memory. After I saved the files in BOOT mode I pressed and held RESET & DETETE while the controller boots up. Then I had the regular screens with everything cleared. Then I went back into BOOT mode and did a SRAM restore from the files that I had just saved and everything was back to normal. Please realize that this is a long shot and if it works buy a lotto ticket. You are going to have to clear memory anyways and this will get you to a point where the controller is back to out of the box and you can change screens. If RESET & DELETE doesn’t clear you system alarm then you have a bad SRAM card in the controller.
    Feb 2013
    Thanks for the input - I tried that, but something like an EOF must be missing or corrupted. Attempting a backup in boot mode hangs the controller (2+ hours...!). Still no response from Sharp or FANUC; I've got a bricked SV2412 until I can get an SRAM file from somebody. :<
    Apr 2011
    Do you get normal screens after the RESET & DELETE? Forget the SRAM files for now.
