Need Help! Sharp 1640L Lathe Spindle Problem
Results 1 to 2 of 2
Thread: Sharp 1640L Lathe Spindle Problem
    Registered bcavender's Avatar
    Apr 2016
    Default Sharp 1640L Lathe Spindle Problem
    A friend has a 1640L with a CamLock system that holds the spindle to the head. He started to simply face a small bar and the entire spindle came off and fell.
    I went over and we put it back on, but I noticed there wasn't any detent or locking "click" when you engaged the cams. Seems odd like I am missing something. Couldn't find a Sharp manual last night for a search.
    Anyone know the trick here on how to lock these cams in so we can avoid a spindle problem again?
    Thanks!!!
    B
    Oct 2004
    Default Re: Sharp 1640L Lathe Spindle Problem
    tighten them up. There's no detent. Clean everything well before putting it together.
