Controller for 230v 1.75 hp treadmill motor? - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 14 of 14
Thread: Controller for 230v 1.75 hp treadmill motor?
  1. #13
    Dec 2003
    Default Re: Controller for 230v 1.75 hp treadmill motor?
    Might be easier to do it with a SPST switch and use a relay, the switch that KB uses and comes with the enclosure models have a terminal for the braking resistor and the I1 & I2 terminals, it also has a special centre position stop that prevents you from going from FWD to REV in one motion.
    If you need the switch if you have a KB or Baldor motor rep near you they should stock it.
    Member Azalin's Avatar
    Mar 2014
    Turkey
    Is it something Baldor/KB branded/manufactured? I couldn't find info about SPST on-off-on switches. The one I have is: IC158 6 AYAKLI ON-OFF-ON B
