Frankenstein servo- new drive on a old servo
Results 1 to 2 of 2
Thread: Frankenstein servo- new drive on a old servo
    Jan 2011
    Default Frankenstein servo- new drive on a old servo
    I had an idea and I'm not even sure if it's possible, but can you take an older servo (early 90s Kollmorgen Goldline Brushless PM servo) and use a new and modern drive, something like a Sureservo2 drive? If I make sure the drive is rated for the motor and I use the correct encoder on the servo, can I get by with it and use the auto tuning feature?
    I'm doing a controller retrofit and while my servos and drives are functional, I'd prefer to have at least a modern drive. Since my servos are good, I'd love to use them if possible but I don't know if that's even a doable thing. Hopefully you guys have some insight on it.
    Thanks!
    Member cncmakers001's Avatar
    Jul 2011
    China
    Default Re: Frankenstein servo- new drive on a old servo
    It is better to change all drivers to new and modern drives, if not it could not compatible and causing many troubles.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
