Looks custom industrial from the likes of Omron or Phoenix.
Motor looks pretty big.
I envisage you having to take them off and use an alternative.
I have what seem to be servo motors. There are no stickers on the outside of the motors for identifying. I can identify is a Sumtak encoder of some sort. The connector seems to be a latch type. Thank you.
- Need Help!- Servo identification
- Need Help!- Identification of a Servo-Motor Hitec HS-311
- servo identification
- Need Help!- Clifton servo identification
- Servo motor identification help
They appear to be BLDC, if so the encoder may have commutation tracks on them, as well as the usual quadrature tracks?
DON'T MOVE THE "ENCODER". If you do, it could cost you more than it's worth to have it realigned, for proper commutation.
Sent from my SM-N975U using Tapatalk
even if you can identify the servos you have a problem trying to get compatible drives.
Argon drives by Granite Devices for instance are servo drives made to accommodate a wide range of servo motors, but they cost over $400. Even then there is scope for
mismatch between an unknown servo and an Argon drive.
A brand new 750W Delta B2 series AC servo, drive and cable kit cost $435.......everything matches perfectly, no mess, no shagging around.
Craig
