It depends on how your machine controller works. Could be a prox sensor or encoder index pulse or possibly a combination of both. Normally all of the control is in the machine controller, the servo amp and thus the motor, just does what it is told to do by the machine controller. The normal analog command signal is a +/- 10V signal from the machine controller that controls the motor speed or torque.
