I'm building a new controller using DG4S-08020 drives. These are on small servos that only draw about 3 amps.
I've never tuned servos before so am trying to get a handle on the process. So I'm a beginner at this.
When I first hooked up a servo to one of the drives I was able to get smooth movement using the movement arrows in UCCNC. However after some attempts at tuning with your ServoConfigorator3 software I'm not making much headway. I'd like to go back to the initial setting that was in the drive before I started working with the ServoConfigurator3 tuning software for a "fresh start".
Is there a way to reset the DG4S back to factory default settings?
