Speed synchronization of induction motor and delta servo Asda A2
Dear Master,
I will make a cutting machine project, the cutting unit uses an induction motor with a Delta C2000 Inverter and an incremental encoder (master) is installed, the material to be cut is using the ASDA A2 - M Servo Delta, is this possible, if so, how are the settings, thank you for all.
