Got something working Needed to invert the feedback direction in the Granity software. Encase someone else ventures down this road here is my settings so far.
Troy
Hello,
Got a 4th axis that has a Fanuc redcap servo. Currently trying to see if the Granite Devices Argon drive will work. What i have so far is drive connected and setup within the Granity software.
Currently motor will only snap to a pole position if it is near a pole when testing with Granity Jogging in Torque Mode. If motor is already at a pole position it will not rotate, just holds at my peak current of 4.6A. Has anyone succesfully tuned an alpha Faunc servo to work with a Argon? Or maybe another drive?
I have adapted a USDigital Incremental encoder with 2000ppr to the servo.
Attached servo motor plate.
Thanks for any info,
Troy
www.tsjobshop.com, www.homecncstuff.elementfx.com
Troy
Which US digital encoder did you use? How are you handling motor commutation?
Number of encoder is HD25-2000-N-N-L-IE-D
