Newbie Yaskawa SGDB-02VN with Mach3
Results 1 to 2 of 2
Thread: Yaskawa SGDB-02VN with Mach3
    Member averellan's Avatar
    Aug 2019
    Default Yaskawa SGDB-02VN with Mach3
    Hello
    I am trying to get an old Biesse rover 23 running with mach3 and Smoothstepper Ethernet 51 I/O Motion controller. Looking in the manual, I have found a "connection and wiring" for Mitsubishi and I thought I could use this but with smoothstepper instead using pin an dir..
    I am stuck with the pinout from the SGDB-CANV, I can not find any manual, after days of looking, wich pins are what in the 13 pins jacket labaled 1CN.
    Any ideas?
    Attached Thumbnails Attached Thumbnails Yaskawa SGDB-02VN with Mach3-screenhunter_1005-sep-03-23-07-jpg   Yaskawa SGDB-02VN with Mach3-screenhunter_1004-sep-03-23-06-jpg
    Member dm17ry's Avatar
    May 2007
    Default Re: Yaskawa SGDB-02VN with Mach3
    SGDB-xxxN are early Mechatrolink-I drives. the bus gets connected to the blue 8-pin honda connector at the top left. 1CN circled in red is for limit switches and the like.
    the manual is available on the web, google for SIE-S800-26.4B. i doubt about mach3/SS...
