Thanks for all your help. I would have bought the S versions if I would have known. I didn´t know about that pixe100 that converts step/dir to anolog. I didn´t have enough time to research. I was lucky just to get a drive that will work with mach3 and be compatible with the servos. I took advantage of a trip to the states to buy this D-Tran and three drives.
This robot moves rather far per rev. Just guessing real quick I would say about 1 inch. I will be using it as a cnc router not a mill so I would think this would be great for woodworking. This is so much better quality than I could have ever have built. the only thing is that it uses greese. But I had already figuered out to put a positive filtered air flow through the three ballscrew channels preventing 99% of the sawdust from getting in there. Not to mention having a high powered vacuum system.
