Need Help! Setting up AMC BE25A20 in torque mode? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: Setting up AMC BE25A20 in torque mode?
  1. #21
    Mar 2005
    Default Re: Setting up AMC BE25A20 in torque mode?
    Quote Originally Posted by Al_The_Man View Post
    I have made up boards in the past very similar to this, I prefer to use Vero Strip Board Board and the other components from Digikey.
    Boards. half way down. https://www.futurlec.com/Protoboards.shtml
    Thanks Alot.
  2. #22
    Mar 2005
    Thanks Alot The Man
  3. #23
    Mar 2005
    Hey Sean, where did you wire the drive fault into the 7i77 Mesa board.
  4. #24
    Mar 2005
    Quote Originally Posted by CATCH22 View Post
    Thanks Sean, now all I have to do is figure out how to read electrical schematics. Lol
    I made one of these boards that Sean so kindly shared with me, but I can't figure out where the fault goes into the 7i77 board, can't see anything in the manual about it.
    If anyone can help me out I would really appreciate it.
    Thanks Mike
  5. #25
    Apr 2005
    Thanks Mike
    Mike, I apologize, I must have missed the notification there was a reply in the thread. Did you get this figured out yet? I have each of the fault outputs from the board going into one of the 7i77 24VDC capable inputs. It really doesn't matter which one. I have that input pin then set as a fault for the axis in the hal configuration (IIRC I did that in pncconf). I know that isn't real specific. I can go grab the configuration from the machine if it would help.
    Sean
  6. #26
    Mar 2005
    Quote Originally Posted by seanano View Post
    Sean
    Thanks Sean, but I have it up and running now.
    Thanks Mike
