Drivers for Fanuc AC Motors
Results 1 to 2 of 2
Thread: Drivers for Fanuc AC Motors
    Registered JonathanTwynham's Avatar
    Feb 2019
    Default Drivers for Fanuc AC Motors
    Hi.
    I posted in the Fanuc forum, but figured it may be more appropriate to post here..
    I am wanting to retrofit a Matsuura MC1000V with a Fanuc 3000C controller with more modern kit but am struggling with either finding appropriate drivers and driver/motor combinations.
    I have found that the X and Y motors are Getty/Fanuc AC Servo Motor 10-2000M models and the Z axis is a Getty/Fanuc AC Servo Motor 20-2000M and the spindle is a Getty/Fanuc DC Motor 5-1PM.
    I believe the 20-2000M is a 23Nm motor and the 10-2000M's are 12Nm.. I cant find any 23Nm motors or drivers that are suitable.
    If possible I'd like to keep the original motors and just run new drivers.
    I am planning on using a U300-Eth to power everything with Mach4 Industrial..
    My ultimate aim is to get the Matsuura running nicely and add an A axis.. I do a lot of vintage restorations and would be great to be able to machine the parts in house such as camshafts etc.
    Jonathan
    Dec 2003
    Default Re: Drivers for Fanuc AC Motors
    If they are Fanuc AC servo's, they use a proprietary means of commutation encoder that produces a pseudo sine wave.
    The do not interface with the typical AC or BLDC drives.
    There was a Zone member that came up with a convertor scheme he was offering.
    I have actually replaced the encoder with the standard BLDC encoder and ran them as BLDC for standard drives.
    Attached Files Attached Files
