- Problem With Yaskawa Varispeed 616G5
Hello everyone,
I have a problem with a Yaskawa Varispeed 616G5.
I have a GF error - Ground fault.
I tested the engine, no losses to the ground. I also removed the motor cables on the varispeed and I still have the same error.
Is there the option to remove the error and the drive is HS?
Has anyone ever had this problem?
- You may not post replies
- You may not edit your posts
Forum Rules
