How to not over power a AC servo drive - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 15 of 15
Thread: How to not over power a AC servo drive
  1. #13
    Registered CitizenOfDreams's Avatar
    Nov 2012
    Default Re: How to not over power a AC servo drive
    Quote Originally Posted by damunk View Post
    [/B]
    why not every one just use 12V and not risk blowing with 24V.
    24VDC is a common standard for automation. It has quite a few advantages:
    - Low enough to be safe if someone touches it.
    - High enough to withstand electrical noise from big motors, powerful VFDs and plasma arcs.
    - Carries enough power to energize heavy stuff like contactor coils.
    - Does not need thick wires to go long distances.
    As far as "blowing" stuff, 12 volts can make some spectacular sparks too. Ever dropped a wrench (or a spanner as you call it in UK) across car battery terminals?
    does it means by 12-24v that you can use 15V or 16V
    That is correct. The input optocouplers will work at any voltage between 12 and 24.
  2. #14
    Gold Member Jim Dawson's Avatar
    Dec 2013
    [/B]
    even with diff voltage. yeah i can see it says 12-24v.
    You could use 12V
    Yes, but the most common power supplies in that range are 12 and 24V.
    Jim Dawson
    Sandy, Oregon, USA
  3. #15
    Mar 2017
    United Kingdom
    Lads, thanks for sorting this out for me. Worked a treat!
