Need Help! Yaskawa Varispeed 626VM3 Fault A00
Results 1 to 5 of 5
Thread: Yaskawa Varispeed 626VM3 Fault A00
    Jul 2007
    Default Yaskawa Varispeed 626VM3 Fault A00
    I'm receiving a spindle alarm on my Hurco Mill that has a Yaskawa 626VM3 servo drive.
    The machine was turned off over the weekend. When I boot up the control The display on the drive has F-A00.
    Please let me know what this alarm is and what can be done to correct it.
    Member mactec54's Avatar
    Jan 2005
    Default Re: Yaskawa Varispeed 626VM3 Fault A00
    Quote Originally Posted by darrelt View Post
    How are you powering your machine this is what a F-A00 fault is
    Attached Thumbnails Attached Thumbnails Yaskawa Varispeed 626VM3 Fault A00-626-vfd-fault-f-a00-png
    Mactec54
    Jul 2007
    When the main power switch on the electrical panel is turned on the control boots up.
    Then there's a green power on PB in the center of the pendant I push then the cycle start PB.
    Then the machine would be fully powered up and ready to reference.
    5 seconds after the power on and cycle start PBs are push is when the spindle alarm occurs.
    Attached Thumbnails Attached Thumbnails Yaskawa Varispeed 626VM3 Fault A00-20181001_083151_resized-jpg
    Jan 2005
    What are you using to power your machine Electrical Power supply
    Mactec54
    Did you resolve this issue
    Sent from my Moto G (5) Plus using Tapatalk
    tgdesign's Avatar
    Dec 2020
    I have the same issue, so how did you fix the problem
