The driver also allows resolver feedback. So maybe a motor with resolver like Allen Bradley MPL-A420P-HJ72AA
OK I put that motor aside because this is going to be very complicated. I better get a motor that will work with the drive.
Looking at the 2nd hand motors of a local seller I've found an Allen-Bradley H4050-P-H04AA servo. Feedback method is TTL (Line Driver output). What do you think?
https://literature.rockwellautomatio...m007_-en-p.pdf
https://www.cnczone.com/forums/attac...d=404238&stc=1
Suat
Proud father, C# developer, Model heli pilot, newbie free time machinist for hobby
Suat
If using a resolver motor, it has to be compatible with the drive.
I have used the A.B. motors in the past, they are nice motors,
Al
They look very compatible to me but I don't trust myself
Image 1 and 3 is from the drives manual. Image 2 is the motor.
https://www.cnczone.com/forums/attac...d=404254&stc=1 https://www.cnczone.com/forums/attac...d=404258&stc=1 https://www.cnczone.com/forums/attac...d=404260&stc=1
Suat
A person sells this motor on letgo.
If I read the plate correct the id is H-4038-M-H00AX but there is no data on the reliance electric H series manual. Probably a special order product but still there has to be some info on the internet.
https://www.cnczone.com/forums/attac...d=404474&stc=1
Suat
The ABB MicroFlex E150 drive does allow all types of encoders, like the AKD you mention. Do you think I can drive the BMH0703T32F2A with it?
One thing I noticed with the motor is that the encoder wants 7-12vDC while the E150 provides only 5vDC. I guess I can provide that 7-12vDC externally to the motor encoder.
Suat
ABB E150:
https://www.cnczone.com/forums/attac...d=404718&stc=1
BMH0703T32F2A encoder:
(Absolute multiturn 128 Sin/Cos periods per revolution)
https://www.cnczone.com/forums/attac...d=404720&stc=1
Suat
Come on guys. Help me pick an encoder for the 10 pole motor.
I'm struggling with a parameter "direction". Please see the attached. I have no idea what "direction" means.
PDF: https://www.cui.com/product/resource/amt31.pdf
https://www.cnczone.com/forums/attac...d=404958&stc=1
Motor is BMH0703T32F2A
Suat
I finally managed it to work.
What happened to the "Video" tag in the post editor? Is it removed?
Suat
Added a pot for analog velocity control.
Suat
