Another servo question - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 50 of 50
Thread: Another servo question
  1. #41
    Member Azalin's Avatar
    Mar 2014
    Turkey
    Default Re: Another servo question
    OK I put that motor aside because this is going to be very complicated. I better get a motor that will work with the drive.
    Looking at the 2nd hand motors of a local seller I've found an Allen-Bradley H4050-P-H04AA servo. Feedback method is TTL (Line Driver output). What do you think?
    https://literature.rockwellautomatio...m007_-en-p.pdf
    https://www.cnczone.com/forums/attac...d=404238&stc=1
    Attached Thumbnails Attached Thumbnails Another servo question-ab_h-jpg
    Suat
    Proud father, C# developer, Model heli pilot, newbie free time machinist for hobby
  2. #42
    Mar 2014
    Turkey
    The driver also allows resolver feedback. So maybe a motor with resolver like Allen Bradley MPL-A420P-HJ72AA
    Suat
  3. #43
    Dec 2003
    If using a resolver motor, it has to be compatible with the drive.
    I have used the A.B. motors in the past, they are nice motors,
    Al
    Mar 2014
    Turkey
    They look very compatible to me but I don't trust myself
    Image 1 and 3 is from the drives manual. Image 2 is the motor.
    https://www.cnczone.com/forums/attac...d=404254&stc=1 https://www.cnczone.com/forums/attac...d=404258&stc=1 https://www.cnczone.com/forums/attac...d=404260&stc=1
    Attached Thumbnails Attached Thumbnails Another servo question-abb_resolver_1-jpg   Another servo question-motor_resolver-jpg   Another servo question-abb_resolver_2-jpg
    Suat
  5. #45
    Mar 2014
    Turkey
    A person sells this motor on letgo.
    If I read the plate correct the id is H-4038-M-H00AX but there is no data on the reliance electric H series manual. Probably a special order product but still there has to be some info on the internet.
    https://www.cnczone.com/forums/attac...d=404474&stc=1
    Attached Thumbnails Attached Thumbnails Another servo question-xyz-jpg
    Suat
  6. #46
    Mar 2014
    Turkey
    Quote Originally Posted by mike_Kilroy View Post
    Very true! Most drives only accept a single type of feedback and are limited to certain speeds, number of motor poles, and more. So a long search is required to find the right one.
    Your alternative is to buy a state of the art latest technology drive that "does it all." Then you do not have all that search time. Make note of such drives for future use! That way you can utilize those $1500 ebay motor finds for $ 50.
    One such is the Kollmorgen digital AKD drive that accepts resolvers, encoders, sine encoders, absolute encoders of many flavors (tamagwaw, renishaw, heidenhain, endat 2.1, endat 2.2, hyperface, DSL, BISS, encoders, halls, etc) and can run any servo motor from 2 thru 64 poles. And has analog input, step/dir input, and just about any digital input out there (ethernet/IP, sercos 3, ethercat, canopen, telnet, modbus, profibus, etc). And one that does autotune and more importantly auto phasing of motor to feedback. And is priced like the 'cheap' AC servo drives (not as low as the low cost BLDC ones). And can run a DC motor with encoder feedback or an AC induction motor (these are more unique applications). And has a nice easy to use windows GUI.
    In all cases, double check with the manufacturer that your motor, feedback, and input requirements match their drive.
    The ABB MicroFlex E150 drive does allow all types of encoders, like the AKD you mention. Do you think I can drive the BMH0703T32F2A with it?
    One thing I noticed with the motor is that the encoder wants 7-12vDC while the E150 provides only 5vDC. I guess I can provide that 7-12vDC externally to the motor encoder.
    Suat
  7. #47
    Mar 2014
    Turkey
    ABB E150:
    https://www.cnczone.com/forums/attac...d=404718&stc=1
    BMH0703T32F2A encoder:
    (Absolute multiturn 128 Sin/Cos periods per revolution)
    https://www.cnczone.com/forums/attac...d=404720&stc=1
    Attached Thumbnails Attached Thumbnails Another servo question-e150enc-jpg   Another servo question-bmhenc-jpg
    Suat
  8. #48
    Mar 2014
    Turkey
    Come on guys. Help me pick an encoder for the 10 pole motor.
    I'm struggling with a parameter "direction". Please see the attached. I have no idea what "direction" means.
    PDF: https://www.cui.com/product/resource/amt31.pdf
    https://www.cnczone.com/forums/attac...d=404958&stc=1
    Motor is BMH0703T32F2A
    Attached Thumbnails Attached Thumbnails Another servo question-amt312d-1024-8000-10-jpg
    Suat
  9. #49
    Mar 2014
    Turkey
    I finally managed it to work.
    What happened to the "Video" tag in the post editor? Is it removed?
    Suat
  10. #50
    Mar 2014
    Turkey
    Added a pot for analog velocity control.
    Suat
