Another servo question - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 50
Thread: Another servo question
  1. #21
    Member Azalin's Avatar
    Mar 2014
    Turkey
    Default Re: Another servo question
    Yes, servo is 220v 3ph
    Suat
    Proud father, C# developer, Model heli pilot, newbie free time machinist for hobby
  2. #22
    Mar 2014
    Turkey
    By the way, the ABB drive and the servo has very similar resolver values but I really have no idea if they are still the same or totally different things.
    Attached Thumbnails Attached Thumbnails Another servo question-motor-png   Another servo question-drive-png
    Suat
  3. #23
    Mar 2014
    Turkey
    Looking at the images on my previous post, I really have no idea which pin goes where. I'd like to get some assistance on this.
    Suat
  4. #24
    Member mike_Kilroy's Avatar
    Sep 2010
    These Are 100% incompatible. One is a resolver other is a digital enc.
    Sent from my SM-G900V using Tapatalk
    Mike@@@KilroyWasHere.com
  5. #25
    Mar 2014
    Turkey
    Ouch that hurt. But thanks.
    The drive also support incremental encoder feedback. So does this sound doable: remove the encoder from the servo (and the brake because I don't need it) and install an incremental encoder to the servo.
    Sent from my MI 5s Plus using Tapatalk
    Suat
  6. #26
    Sep 2010
    Quote Originally Posted by Azalin View Post
    Sure but... the new encoder must also have COMMUTATION tracks (3 of them) and they must match up to your motor's number of poles. Gets complicated pretty fast. do you know how many poles your motor is so you can buy the correct encoder?
  7. #27
    Dec 2003
    Also If fitting a encoder with commutation tracks, you need a double beam 'scope to align it, if it is not keyed somehow.
    To find the number of poles, short the three stator wires and rotate one revolution by hand and count the 'bumps'.
    Mar 2014
    Turkey
    To the manual pole number is 5.
    I did a quick search to find an encoder but couldn't find one.
    Suat
  9. #29
    Mar 2014
    Turkey
    Will a line driver output incremental encoder work? Because I already have one and it would be nice if I could use it. This one: E50S8-1024-6-L-5
    Suat
  10. #30
    Mar 2014
    Turkey
    Encoder input of the drive:
    https://www.cnczone.com/forums/attac...d=404202&stc=1
    Attached Thumbnails Attached Thumbnails Another servo question-abb_encoder_input-jpg
    Suat
  11. #31
    Jun 2011
    Motor (magnet) poles have to be an even number. Is it 5 pole pairs?
  12. #32
    Mar 2014
    Turkey
    Ah, yes, sorry. 5 pairs.
    Suat
  13. #33
    Sep 2010
    google "encoder with commutation" gets me like 100 sources...
    example:
    http://encoder.com/products/incremen...s/model-15t-h/
    http://encoder.com/core/files/encode...th20180220.pdf
  14. #34
    Mar 2014
    Turkey
    What confuses me is, as the motor has 10 poles, do I need an encoder with 10 channels or 12 (10 for poles and A+B). I'm asking because I can't find an encoder with 10 channels. They are mostly 9 or 12 (as far as I see).
    Suat
  15. #35
    Dec 2003
    The encoder has the normal A & B quadrature track and also the commutation tracks according to the pole count, Renco encoders used to be a really good cheaper source, but have since been taken over by Heidenhain so the prices are a little higher.
    You need to order the encoder resolution you need and the pole count pairs.
    The PDF shows the generated AC from the stator relative to the commutation.
    (What you would see on the 'scope).
    Attached Thumbnails Attached Thumbnails Another servo question-commutation-pdf
    Mar 2014
    Turkey
    Are Renco encoders up to 4 poles?
    Suat
  17. #37
    Dec 2003
    I thought your motor was 10 pole?
    Mar 2014
    Turkey
    Yes, 10 poles. Why?
    Suat
  19. #39
    Dec 2003
    Is it a 3phase/termination stator?
    Mar 2014
    Turkey
    Suat
