Reg:Servo motor to be used a spindle motor
Results 1 to 5 of 5
Thread: Reg:Servo motor to be used a spindle motor
    Feb 2015
    Default Reg:Servo motor to be used a spindle motor
    Hi everyone,I just want to know whether a servo motor in FANUC can be used as a spindle motor??
    Registered tienduongcnc's Avatar
    Feb 2015
    hi keviv2484,
    I've seen servo motor in STAR lathe machines, they were used as drilling spindle.
    But I think it's rarely being used this way.
    Spindle motors give higher rotation speed & torque for cutting purpose.
    Feb 2009
    Default Re: Reg:Servo motor to be used a spindle motor
    Yes they can, if your machine expectations permit it. They work quite well actually.
    Dec 2003
    Quote Originally Posted by keviv2484 View Post
    AC or DC? The DC are fairly easy as Drives are quite flexible, The Fanuc AC has proprietary commutation, so either needs a convertor, or as I did, change the encoder to BLDC type with standard commutation tracks. I Used a ±10vdc drive so I was able to use a A-M-C BLDC drive.
    Feb 2007
    canada
    What rpm are you planning on running ?
    The bearings in a spindle motor are rated for high rpm, not in a servo. Also the balancing of a 10,000 rpm Fanuc spindle motor is a lot more precise than a servo.
