Do you have photos of the bridge I made?
Hello Guyz!
Can anybody else confirm this pinout?
By my power supply I cannot measure any voltage by the output connector, so it seems to be broken. I found a replace part with the following rated current output:
5V / 15A
24V / 2.7A
15V / 2A
-15V / 2A
What do you think, is this enough?
Thanks,
Gábor
Have you resolved this issue? I am currently receiving the error F-E02 and I need assistance on how to resolve it. Based on the manual, the source of the issue is Data in memory (NVRAM) exceeded upper or Lower limit. There is a parameter C2-01 that shows as higher than upper limit, but the drive will not allow me to change this parameter. Any suggestions?
