Yaskawa Varispeed 626VM3 Help - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 44
Thread: Yaskawa Varispeed 626VM3 Help
  1. #21
    Aug 2016
    Mexico
    Default Re: Yaskawa Varispeed 626VM3 Help
    It is advisable to change the thermistor, but as it goes inside the motor, the other option is with a 100 ohm resistor
  2. #22
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by Christian_ View Post
    Hi guys, I have a 626vm3 with an f-600 fault can anyone help out?
    Your Fault is a power supply problem, when turning on power
    How are you powering the VFD or Machine
    Mactec54
  3. #23
    Jan 2005
    Quote Originally Posted by experto crede View Post
    Hello everyone
    I am reconditioning an old hitachi ht 25g. Variseed 626vm3c has been used to control the turret motor. I continuously get an error F-902. Since i am using encoder control, the connector 2CN is not used. Acccording to the manual, thermistor inputs have to be given to pins 8 and 9 of 2CN. I tried giving the input to those pins but the parameter V7-1 still shows temperature of -27 degree C. Apparently i somehow need to get this above -10 to get the drive to work. If anyone else has used encoder control and has been able to run the motor, please do let me know the connector and pin numbers where you connected the two thermistor wires. I just need to get the parameter V7-1 ro read something above -10 degree C.
    Thank you in advance !
    Try 11 and 12 for the thermistor inputs
    Mactec54
  4. #24
    Hello,
    I am having a Yaskawa Spindle Drive Varispeed 626VM3 is having Alarm F-E04. It means Motor Code Setting Error. I am unable to resolve it. If you know any solution please tell me. Can you please tell which parameter of this drive is responsible for Drive Capacity Code.
    Prabhsimran Singh
  5. #25
    Jan 2005
    Quote Originally Posted by prabhs98 View Post
    Hello,
    Prabhsimran Singh
    The Drive has to match the Motor Capacity or have a larger Capacity, below is what you would set for your motor spec's
    Attached Thumbnails Attached Thumbnails Yaskawa Varispeed 626VM3 Help-motor-code-parameter-png   Yaskawa Varispeed 626VM3 Help-motor-code-png
    Mactec54
  6. #26
    Apr 2018
    Jordan
    I have the same problem
    but what you mean by a power supply problem ?!
    is it control power supply
    or power interface card power (fuses & transformers are working properly )
    and starting the drive (not installed in the machine) by supplying 3 phase 220 VAC with an electrical contactor and contected to an encoder to avoid encoder problem !!
    power supply control output of the power supply as follow at 24 CN
    1. Ground
    2. Ground
    3. 5 VDC
    4. 5 VDC
    5. 15 VDC
    6. -15 VDC
    7. 24 VDC
    8. 5 VDC
    Any suggestions !!!!???
  7. #27
    can you please forward the user manual to my mail id : macrocontrolshyd@gmail.com
  8. #28
    Hello,
    Prabhsimran Singh
    Did u solve the issue
    Sent from my Moto G (5) Plus using Tapatalk
  9. #29
    milos2711's Avatar
    Nov 2019
    i have a problem with F-A00 error on Varispeed626VM? can anyone help me?
  10. #30
    Member Vuhuynh's Avatar
    Oct 2020
    Hello
    I have 1 hitachi seicos 10L cnc lathe
    The spindle adopts Yaskawa 626VM3 18.5KW inverter.
    F_C41 error is reported.
    Please ask what is the error, and how to fix it.
    Thank you!
  11. #31
    Jan 2005
    Quote Originally Posted by Vuhuynh View Post
    Hello
    Thank you!
    Did someone change some Parameters and is the fault showing C1 41
    Mactec54
  12. #32
    Oct 2020
    The machine is running, it has error F_C41
    The machine parameters I tracked according to the machine documentation have not changed.
    I also don't know why?
    Thank you!
  13. #33
    Jan 2005
    Thank you!
    Don't know if that is a fault or a Parameter problem this is not a listed fault for that VFD Drive there is a Parameter that is C1-41
    Something to check is the motor thermistor and the cooling fan is clear and working
    Attached Thumbnails Attached Thumbnails Yaskawa Varispeed 626VM3 Help-c1-41-jpg
    Mactec54
  14. #34
    Oct 2020
    Post Re: Yaskawa Varispeed 626VM3 Help
    The machine is processing, the error F_C41 on the rating board on the VDF, not the parameter C1-41.
    Then the machine stopped completely.
    Parameter C1-26: 4000 , C1-41: 0000
    Thank you!
  15. #35
    Jan 2016
    Hello, I have the F-905 error. Would someone be able to tell me where the thermistor is? I have found one thermistor labeled th2 on the board, but adding resistor here made no difference. My display unit was showing -30c before and after. perhaps I have the wrong one, or maybe something else going on. here is the picture of the v-13 output showing the temp reading and an arrow to the thermistor I was playing with . Thanks in advance.
    https://www.cnczone.com/forums/attac...d=469224&stc=1
    Attached Thumbnails Attached Thumbnails Yaskawa Varispeed 626VM3 Help-20210901_111526-jpg
  16. #36
    Jan 2005
    Quote Originally Posted by ggtech View Post
    The F905 is the Heatsink thermistor or the wiring for it should show -10c or lower
    Mactec54
  17. #37
    Jan 2016
    Thanks, I realize now that I was not looking at the right heatsink. I removed the unit from the machine and there is a large heatsink with a fan at the back. Its sunk into the machine cabinet and was not visible.
    Now that I am looking at the correct heatsink I hope I can locate the thermistor.
  18. #38
    Member Teetop's Avatar
    Sep 2021
    I'm having they exact same issue on a Tree mill. I have a potentiometer from an AC motor. how would you wire that to the thermistor
  19. #39
    Jan 2016
    Quote Originally Posted by Teetop View Post
    Mine is now fixed. Measure your thermistor before doing anything. Mine turned out to be working. It should show some resistance. Blast it with cold air from a computer cleaner can, it should change.
    In my case it ended up being a bad trace on the board going from the the ribbon connector to a capacitor on the board. Had to take it to a repair shop and it took the technician some time to find the fault. He ran a wire between the 2 points.hope this info helps others.
  20. #40
    Jan 2005
    You would not wire the pot to anything, to do with the thermistor
    Mactec54
