Need Help! How to get the firmware from a MR-J2S-B servo amplifier?
Results 1 to 10 of 10
Thread: How to get the firmware from a MR-J2S-B servo amplifier?
    Mar 2012
    China
    Default How to get the firmware from a MR-J2S-B servo amplifier?
    I have several bad MR-J2S-B servo amplifers and I do not really want to give up them. I judge the trouble reason is that the firmware of main controller---SH7065 had been lost. Fortunately, I have some good amplifers in hand with the same model. Can I get the firmware from a good one and re-programme those bad? or where can I downlaod the firmware I need?
    Please help!
    Thanks and Regards,
    greatwall2
    Member dm17ry's Avatar
    May 2007
    you can reflash them with SHflash.exe utility which comes with SETUP161E. when it asks to set the boot mode short pins 5-6 of the CON6 connector and switch on the power. the 7-seg LED display should stay blank. PM me with you email and i will send you a firmware image.
    Mar 2012
    China
    Quote Originally Posted by dm1try View Post
    Thanks a lot. My mail address has been sent to you by PM and I expect your reply.
    Regards,
    greatwall2
    *Registered User* collinslin's Avatar
    Dec 2018
    Default Re: How to get the firmware from a MR-J2S-B servo amplifier?
    How can use SHflash.exe to chang firmware?
    May 2007
    see message #2. why do you want to do it?
    Dec 2018
    Hello, sir.
    I am come from Taiwan
    Some things need your help
    My company's machine J2S drive has been discontinued
    MR-J2S-350A-s011 ( Firmware BCD-B26W005 A1)
    but i only can buy MR-J2S-350A( Firmware BCD-B26W005 B6)
    and now My company's machine have trouble can't work need to change driver
    I saw that it can used SH-DSP Flash rom and SHflash?but i don't know how to use this
    Can you teach me how to change Firmware? please
  7. #7
    May 2007
    aha, i see.
    it is possible to do if:
    1. you have a working MR-J2S-350A-S011 drive to read the firmware from.
    2. your standard MR-J2S-350A has a FLASH CPU. see http://yurtaev.com/mr-j-faq.html
    drop me an email at the above link, i will send you a utility which can read the firmware. you'll need a windows pc with MR-CPCATCBL serial cable (the same used for MR Configurator)
    if the firmware can be read, i will convert it fo intel hex format which can be used with SHFlash utility to flash the new drive
    also, you need to read all 255 parameters from the -S011 drive using MR Configurator. to do it, set param No.19 to "ABCD", reboot the drive, read params and save em to a file
  8. #8
    Dec 2018
    Thank you very much for your reply.
    I have read this article before, but I don't know how to operate the process.
    I will read correctly about the parameters.
    But can you tell me the correct read firmware process?
    And how to write the firmware process correctly?
    You are my savior
    my E-mail was collinslin6478@gmail-com
  9. #9
    Sep 2007
    FLORIDA
    Quote Originally Posted by dm17ry View Post
    aha, i see.
    Hi i have the same problem with MR-J2S-100A-S046
    How can i read the old firmware?
  10. #10
    perlik1969's Avatar
    May 2020
    aha, i see.
    Hello sir,
    I have the same problem with MR-J2S-70B.
    I need to unload firmware and parameters from the old and load it to the new servo amplifier.
    Is it possible that another firmware version in the same servo amplifier won´t work with CPU controller correctly?
    Thank you
  11. #11
    Member M7MDBUZZ's Avatar
    Apr 2022
    Thanks for Support!
    I sent you email about MR-J2-40A
  12. #12
    Amir28pic's Avatar
    Feb 2024
    Quote Originally Posted by M7MDBUZZ View Post
    Thanks for Support!
    Hello my friend Please send me the mr-j2sa and mr-j2sb boot and firmware file. Thank you
    amir28pc1@gmail.com
  13. #13
    Amir28pic's Avatar
    Feb 2024
    amir28pc1@gmail.com
