Yaskawa Varispeed 626VM3 Fault A00
Results 1 to 4 of 4
Thread: Yaskawa Varispeed 626VM3 Fault A00
    milos2711's Avatar
    Nov 2019
    Default Yaskawa Varispeed 626VM3 Fault A00
    I have a problem with Varispeed 626VM3 ..
    F-A00 Fault
    Please help?
    What I need to do??
    Member mactec54's Avatar
    Jan 2005
    Default Re: Yaskawa Varispeed 626VM3 Fault A00
    Quote Originally Posted by milos2711 View Post
    F-A00 Fault
    Please help?
    What I need to do??
    Sounds like you may have a main Capacitor problem, the main Capacitors are not charging up correctly
    Mactec54
    BoyceMachine's Avatar
    May 2022
    Did you ever find the cause of the F-A00 fault on the Yaskawa drive? I have the same alarm.
    Jan 2005
    Quote Originally Posted by BoyceMachine View Post
    Same problem then the main Capacitors have not charged on power up, could be just the caps need replacing, which is normal, or the rectifier on the input circuit has given up, there are more parts to the input circuit anyone could have failed, how have you been powering the VFD Drive
    Input Rectifier
    Pre-charge Circuit
    Bus
    Capacitors
    Mactec54
    milos2711's Avatar
    Nov 2019
    yes i solved the problem.
    one of the capacitors or resistors was replaced on the board and then it worked
