Motor encoder alignment - Page 2
Page 2 of 2 FirstFirst 12
Results 13 to 15 of 15
Thread: Motor encoder alignment
  1. #13
    Dec 2003
    Default Re: Motor encoder alignment
    Quote Originally Posted by Azalin View Post
    By magnetic I mean the encoder has no rotating part, it just senses the rotation of a magnet.
    This one: https://www.rls.si/en/rmc22-commutat...mental-encoder
    I see, I believe I tried a similar version made by CUI but it was in the early stages of development and I had varying degrees of success with it.
    Those look similar, if so they are self calibrating, i.e. requires no scope to align.
    Registered Azalin's Avatar
    Mar 2014
    Turkey
    Yes. Just align the rotor to the zero point and set the encoder with a button.
    What I don't know is how to get the rotor to it's zero point. I came across a blog entry today. The poster says if you apply +5vdv to the U phase and - pole to the V phase then the rotor will move to the zero point. Sounded interesting to me.
    Sent from my MI 5s Plus using Tapatalk
    Suat
    Proud father, C# developer, Model heli pilot, newbie free time machinist for hobby
  3. #15
    Apr 2015
    Quote Originally Posted by Al_The_Man View Post
    There are many encoders made this way now as Hall sensors have dropped out of favor now because the simulated hall tracks are much more accurate.
    I used to get mine from Renco, but now they have been taken over by Heidenhain, many of the models have been dropped. But there are many others.
    I have converted Fanuc AC servo motors to BLDC this way.
    You need to know the pole count of the motor, if you short the stator leads and rotate the motor by hand and count the 'bumps' per rev.
    AZALIN, I have never come across a 'Magnetic' encoder as far as I recall.
    Al..
    Thanks for that Al, I will have a look round and see what is available in the UK. Dave
