- Lagun FTV-2S
Lagun FTV-2S
Have a wiring issue I need help with.
If I can figure out to post a picture here I purchased this machine used. After putting power to it, I can’t get the servo’s to turn on. I believe this is a wiring issue in the power panel in the back of the machine.
With no wire diagram I can’t figure out what needs to be fixed. If you have this same machine can you post a picture of the power panel on the back of the machine so I can check my wiring?
Brad
Re: Lagun FTV-2S
Re: Lagun FTV-2S
Ok got a picture up. Now the breaker does not work. That is why it is bypassed.
I have a wire to the left that I do not know where it goes!
The wire for A1 to left of the main breaker.
Any help would be much appreciated!!
- Lagun FTV-2S
- You may not post replies
- You may not edit your posts
Forum Rules
