Biesse Rover G5.12 Yaskawa AE50 Code
Results 1 to 7 of 7
Thread: Biesse Rover G5.12 Yaskawa AE50 Code
    Member ProgrammingApprentice's Avatar
    May 2022
    Question Biesse Rover G5.12 Yaskawa AE50 Code
    We have had an incredibly experienced tech out for about a week working on various machine issues. The day after he leaves, we lose power to our G5.12 flattop router. We receive a Yaskawa flashing code of AE50 which is a mechatrolink communication issue from what I'm reading.
    Our list of Biesseworks error codes read as follows:
    AXS 339> Axis not calibrated. Homing must be performed.
    AXS 830> Watchdog servodrive. Axis X 1
    AXS 796> Violation of digital operation protocol Axis X1
    AXS 830> Watchdog servodrive. Axis Xs 1
    AXS 830> Watchdog servodrive. Axis Y 1
    AXS 796> Violation of digital operation protocol Axis Y1
    AXS 830> Watchdog servodrive. Axis Z1 1
    AXS 796> Violation of digital operation protocol Axis Z1 1
    AXS 830> Watchdog servodrive. Axis Z2 1
    AXS 796> Violation of digital operation protocol Axis Z2 1
    PLC 375> Time-out during communication with a device ax.0
    PLC 372> HALT
    Does this sound like a servo drive communication issue?
    Jun 2005
    Default Re: Biesse Rover G5.12 Yaskawa AE50 Code
    Yup, sounds like it can’t talk to servo drives. Check the power supplies and make sure they are putting out the right voltage.
    May 2022
    I have been checking the servo drives and am getting a flashing error message on 5 of 6. The Majority are flashing with the AE50, a connection issue with Mechatrolink II. The single UY2U1 servo is flashing Pn-. I've checked the voltage, I have also reseated the connections to make sure it is not just a dusty port or bad seat. Any other ideas?
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by ProgrammingApprentice View Post
    PLC 372> HALT
    Check all the Mechatrolink Cables have a good connection to the drive and the hub, plus any other I/0 connections
    Mactec54
    May 2022
    Thanks! I have ordered a Male to Male Usb cable to test out the USB cables in the servo daisy chain. I suspect that one of the USB cables have malfunctioned but should know tomorrow. Thanks for the input!
    Jan 2005
    USB cables, normally they are Ethernet cables??
    Mactec54
  7. #7
    Jun 2005
    machtec54 is correct the mechatrolink communication is normally handled with Ethernet cables. This is because they wanted better noise immunity. Make sure you are looking at the right cables.
  8. #8
    May 2022
    This version of Rover Gantry uses 2 USB cables at the top of each unit, Biesse said this isn't typical but is correct for this model. When hooking the new replacement cable into the UZ2U1 location then linking to the opposite end of that cable, it cleared 4 of the 6 servo drive errors. I tested the new cable on a different link and received no changes. After reinserting it into the original test location, no errors were cleared. I'm wondering if the servo drive/drives have some dust build up or some other cause for malfunctioning ports. Any thoughts?
  9. #9
    Jan 2005
    Check the other servo drive cables
    Mactec54
  10. #10
    May 2022
    After removing all of the USB cables, I have located the inner most plug, cleaned and secured. I was able to clear all but the X axis errors. When swapping the cables to test them, I get all AE50 errors. When I put them back in the position that yielded some positive results earlier, nothing. Being unable to determine if it is a problematic cable or port would require all new wiring, I suppose. If that doesn't yield anything positive, I will replace the longest cable connecting the drives to the back cabinet and see what happens. Does that sound like the logical next step?
  11. #11
    Jan 2005
    Some photos would be good, as this is a commination error that would normally only be cables, it's good that most of the faults cleared, with the cables you changed, seems strange that there would be more than one problem cable at the same time
    Mactec54
